302 block - cleaned and painted - needs rebore - stock at the minute £100
crank - needs grind £50
heads 76 smoggers £50 pair - valves removed
alloy front bit £30
water pump stock iron - cleaned painted £30
offy inlet polished £75 -actually an elderbrook
= with the name smoothed off.
mt valve covers £75
electronic distributor £70
torque convertor and flex plate £30
c4 box £120
new prop yolk £45
hugger headers £50 - painted
-new rocker cover gaskets £10
new exhaust gaskets £10
600 cfm holley - electric choke - no idea on condoition as unsure what to look for £40
750 holley bit rusty on the flaps sir £20
elderbrook air cleaner in chrome, with 2 different size elements £25
front end tube arms cortina based with rack and spindles = rear steer, broken needs fixing, but at £100 its cheap was under a 34
0774 858 2044
