I started work on the templates for the side air inlet for the rear brakes. The lower part of the backing plate will accommodate a 50mm ID fitting which connects to the air pipe which feeds cool air over the brakes (one each side). The blue foam was cut and shaped to fit the backing plate and the curve of the window. Once I like the shape of the foam template a metal one will be made and this will be fitted to the door with the air vents cut into it. Andy
