How not to set valve lash .......... 101:shocked:
Hello i've seen these methods on setting valve lash in 30 + years in print & posted 1,000,000+ times..
Do your self a huge favour and never set valve lash with this methods..
Method # 1 ............ On setting valve lash.
Turn engine to #1 TDC COMPRESSION stroke (ie. rotor arm pointing at #1 plug), then adjust the following rockers...
Adjust the #1 exhaust valve
Adjust the #1 intake valve
Adjust the #3 exhaust valve
Adjust the #5 intake valve
Adjust the #7 intake valve
Adjust the #2 intake valve
Adjust the #4 exhaust valve
Adjust the #8 exhaust valve
Now, rotate the engine 360 degrees (the TDC mark on the crank balancer will be back at the top, but #1 piston will now be on the EXHAUST stroke and the rotor arm will be pointing at #6 plug). Adjust the following rockers...
Adjust the #3 intake valve
Adjust the #5 exhaust valve
Adjust the #7 exhaust valve
Adjust the #2 exhaust valve
Adjust the #4 intake valve
Adjust the #6 exhaust valve
Adjust the #6 intake valve
Adjust the #8 intake valve
The process you should use to adjust each rocker is as follows...
Grasp the pushrod between thumb and index finger and jiggle it up and down. Tighten the polylock until there is no more slack in the pushrod (do NOT tighten it anymore than is necessary to eliminate the slack). THEN, tighten the polylock another 1/2 a turn and lock it. Do this for each rocker following the sequence above.
NEXT:
WRONG & OVER COMPLICATED METHOD # 2 ....Gee i think launch'n the space shuttle is'nt as complicated..:shocked:
NEXT WEB POSTED WAY:
the order I have is;
crank TDC (rotor pointing to no 1) adjust no 8 exhaust
TDC + 45degrees no 2 intake
TD + 90, no 4 exhaust
TDC + 135, no 1 intake
BDC + 180, no 3 exhaust
BDC + 45, no 8 intake
BDC + 90, no 6 exhaust
BDC + 135 no 4 intake
TDC, no 5 exhaust
TDC + 45, no 3 intake
TDC + 90, no 7 exhaust
TDC + 135, no 6 intake
BDC, no 2 exhaust
BDC + 45, no 5 intake
BDC + 90, no 1 exhaust
BDC + 135, no 7 intake
TDC done
Job done...BIG TIME :roll:
:S
:sniff::shake:
I'm not try'n to be a smart A or knock / shag anyone here... the posters of this info i'm sure have the best of intentions
These above methods are okay @ best for your BONE stock American V-8 engine....never use it with modern high output performance engines .
I will cover setting valve lash on hyd & solid cams & ant-pump up lifters & hyd & solid roller cam.'d engines.. no matter what grind profile... or advance or retard ground into cam by manufactor or via crank gear keyway positions or cam gear offset bushing ect ect.
_______________________________________________________________________________________________
Here is why the above methods CAN get you into serious trouble & even cause severe engine damage..... First problem is your using the dizzys position as a refferance point for TDC # 1 buy pointing dizzy rotor to # 1 & # 6 cyln on dizzy and proceeding to set valve lash on various cylinders as listed in above method....there are a few MAJOR problems with this method... IE: What if your dizzy when loaded into engine is NOT in phase with #1 TDC... if so using it as a refferance point to cyln TDC is useless and you would be setting valve whlle most lifters are NOT on the base circle of the camshaft lobes.
Also as we all know the dizzy is able to rotate in block advancing & retarding ignition timing.... this moves the dizzy's rotor
away from # 1 cyln & # 6 cyln terminal on cap & you are NOT on TDC.... now when you try to line up rotor to the terminals on the cap it is way off the TDC of those cyln's and your trying to adjust & the lifters may NOT be on the base circle of the cam on ALL cylinder's....causing you to set improper valve lash....
Using the TDC method also opens you up to making the mistake of adjusting the wrong valve if you mistake the intake for the exhaust valve & possibly mix'n up cyln #'s thiis is very possible... ive seen pro's do it... by being distracked by a hot looking blonde strolling by the shop in pump heels & hot pants ... point is your prone to error & mistakes here big time with this method.
Another major problem with this method is with 1,000's of differant cam profiles used by all differant cam manufactors when designing high performance cams they greatly change cam lobe centers & lobe seperation and lobe flanks & ramp profiles to increase cam lift durations...that are no where near STOCK cam profiles .
And when you set your lash on lifters using TDC method could be no where near the cams base circle of that cyln your adjusting.
Also many aftermarket cam manufactors grind adavance into there cams.... this is to compensate for chain stretch as chain & gears wear.... they also play with adavance & retarding cam grinds to produce more power @ differant RPM ranges & engine combonations............ when this is done.
You may again not be on lobe base circle of ALL lobes when you set lash using TDC method.
An other possiblity for error here is if your cam is ADVANCED OR RETARDED via crank gear key or offset cam gear bushing this could leed to lifters NOT being on base circle of cam when using TDC method
One more recent trick cam manufactors is cam lobe swaping IE 4/ 7 cam lobe switching..where you swiitch cyln's # 4 & 7 around changing the firing order.... now 99% of you will never have this cam in your engine... BUT i've seen fellows @ race tracks set valve lash on engines and the dam thing will not run right.... they used the TDC method and made a major error forgetting they had a 4/7 swap cam in the engine.....bottom line here is to be 100% sure you've got valve lash set correct DO NOT USE THE TDC METHOD
On the rotate engine & stop on degrees marked on damper @ BTDC ATDC / INTAKE & EXHAUST valves ect............way confusing and same reasons above apply.
*On the pushrod GIGGLE method to see if all slack is out of valve train....NEVER use this method it is dead wrong way of checking again due to possible error or judgement IE differant types of rocker arms used on engine & access to pushrod & your finger grip tech and ability to call a giggle or is it a wiggle IE: 140 Kg weight Rugby player checks pushrod giggle VS 60 Kg Horse jockey checks giggle............
Okay here is the fail safe method to adjust your valve lash on any engine & with any type cam profile hyd, or solid or roller cammed.
Remove ALL spark plugs from engine..........load socket on crank damper bolt use 1/2 drive socket is best... bumping engine over with starter motor is NOT recommended to turn engine over... better done by hand
Remove both rocker covers... back off ALL rocker jam nuts or poly locks. Now start @ any cyln you wish.. rotate engine clockwise watch that cyln's only pushrods or lifters rotate engine over till you see the EXHAUST lifter or pushrod of that cyln just start to rise STOP[Now you are ready to set valve lash of the INTAKE on that cyln.. Take a feeler gauge .002 th( FOR HYD CAMMED ENGINES) slide the blade between the rocker arm tip & the valve stem tip now tighten down jam nut till you feel a SLIGHT drag on your feeler gauge & STOP there..now take a 12 point socket or box end wrench load onto jam nut @ 12:00 o'clock postion turn nut clockwise 3/4 turn & STOP valve lash is set on INTAKE valve
Now we are ready to set EXHAUST valve lash of the same cylinder....Rotate engine over till you see the INTAKE valve lifter rise / open all the way up and then start to go down ...when the lifter or valve is ALMOST all the way down or valve is almost closed STOP... you are now ready to set EXHAUST lash.... again load socket on jam nut , load feeler gauge and turn nut till SLIGHT drag is felt on gauge........load socker @ 12:00 O'clock and turn nut 3/4 of a turn STOP ...EXHAUST lash is now set .. now proceed to next cyln & repeat till all cyln's are done.
For engines with ROLLER ROCKERS & POLY LOCKS & hyd cams.. load wrench 12:00 Oclock turn nut to 7:00 postion leave wrench on nut & hold it from moving ... take allen wrench and tighten screw DO NOT let nut move... now tighten nut it will move from 7:00 Oclock to 9:00 Oclock postion = 3/4 of a turn and poly nut WILL BE LOCKED to stud
Now for SOLID CAM ENGINES take your feeler gauge .016 to .028 th ( check your cam spec card for lash spec) and slide between rocker arm & valve tip lock nuts and check for proper clearance after nut is locked.....TIP with COLD engines REDUCE gap by .002 to .003 ths this will allow for engine cyln head expansion when heated up and put your lash / clearance very close toi HOT running lash spec's.
After engine has been run to operating temp stop engine & check HOT VALVE LASH to be sure its spot on
Fee for this lesson mate's 1 pint local brew next UK tour:tup:
Regards Dr.Dee
[email protected]
NEXT:
TDC, no 5 exhaust
BDC, no 2 exhaust
TDC done
Regards Dr.Dee
[email protected]
