Thanks for showing this thread.It answers a great deal of questions for me.What you built there is very much the same as i`d like to.The tube notcher also answers a bugging question.The bender i`ve got I now know to be a bow hydrolic bender like yours.So to clarify, can I bend the right kind of tube for making foll cages on my benders or will I go with tube like you have used in the 34. Nice touch with the wheel nuts, they worked out well. For future plans i may have, what are the rules on what type of tube works in my benders and what does`nt :S
I have to say the Grannada chassis in the photo just looks like a confusing pile of tube! The photos do`nt do it justice
The 'bow n arrow' type bender used to do the 34 will only realistly bend the seamed tube used on the 34, tried CDS years ago on it, waste of time,
the formers on these type benders are measured by I/D, so dont relate to the external tube diameter, it'll still bend it but as the tube is loose in the former it'll come out a bit egg shaped, you need to make a reducer,
real easy, simply a piece of around 20 guage sheet steel around 15" x 4"?,
bend a test piece of tube so that it moulds the sheet to suit the inside of the former, you only need one, it's reusable,
technically, no this isn't the best tube for a cage, but a LOT safer than a car without a cage,
as an example, a guy imported a pre bent cage a few years back that i installed in an early Barracuda, came from one of the big US suppliers, alston? morrisons?
recommended for an 8-9 second car,
what was it made from? regular seamed tube!
what a waste of expensive shipping,
if you want to use the bender you've already got you'll need
CHS 42.4mm o/d x 3.2mm tube, comes in around 7.5m lengths,
i use FH Brundle for mine, about £25 per length last time i got some,
theres a branch near you in Southampton, and they deliver,
hers a link;
http://www.fhbrundle.com/sect-05.htm
i you choose to go the better CDS route,
or the even better 4130 chrome-moly route you'll need a bender like this,
one that supports the complete diameter of the tube while bending,
you'd probably need to farm it out to a chassis shop.
good luck:tup:
