1 - 14 of 14 Posts
Im about to start repairing some of the bodywork on my car, I have folded up some parts to replace the sills and outriggers in Zintec, I have seen a few people spot weld zintec without grinding it back, Is that ok or am I better to grind back where I am going to spot weld??
Be careful of the fumes they are very bad for you. Best to wear a respirator or make sure you have local ventilation on it. Seriously the fumes are about as bad as you can get.
Yes zintec is ok to spotted weld ,it is or was done on mass production car components,done millions of spots on them,on spot welding machine,no PPE health and safety back then though.and I'm still here no probs,though that maybe a matter of opinion :lol:
I thought galvanised coating was the real enemy.
yes i thought galvanising was the bad one to breath in too.
This may help...
MIG welding and angle grinding results in metal vapors.
Aluminium alloy vapour and fumes from zinc coatings are poisonous. Exposure can result in heavy metal poisoning (welding shivers) - flu like symptoms that can persist for a few days. The zinc coating should be removed from galvanised steel before welding, and wear a proper charcoal welding mask when you go anywhere near zinc.
Zince produces Phosgene gas when welded
Phosgene gas was used in mustard gas .
Grinding can also produce the gas
Drink some milk before welding never weld in confined space. Spot welding is the least harmful but still take procautions
Sorry but that's not true; zinc has nothing to do with phosgene. Welding after cleaning with chlorinated hydrocarbons, like some brake cleaners, can produce phosgene though. There's lots of good stuff on welding health hazards here https://www.osha.gov/doc/outreachtraining/htmlfiles/weldhlth.html
I'm a grown up drunk!
Used zintec sheet steel quite a few times but not my material of choice due to the fume issue,
normally thoroughly clean off the area to be welded with a poly disc but you still get a slight powder around the weld and normally use a welding mask as theres still some fumes,
only use now if its a premade panel that has come in zintec.
Checked out the site here is a quote
"The subject can then appear to be more susceptible to the onset of this condition on Mondays or on weekdays following a holiday than they are on other days"
I worked with zinc coated sheet for many years as long as reasonable precautions are made then spot welding should not. Be a problem .
The milk has not been proven to work but its not been proven that it doesn't work.
Its just an added precaution and it tastes nice.
Nowheresville
Zintec is more or less just very thin galvanising.
Ian, do you mean proper electric resistance spot-welding, which shouldn't be a problem (although always best to take precautions) or MIG/TIG spot-welding, which will affect a larger area and hence produce more fumes including the hazardous white dust floating about?
1 - 14 of 14 Posts
