What would make a tacho surge ? I've fited an electronic dizzy, ticks over fine, no misfires etc but the tacho will remain steady and then either when depressing the throttle or juss by itself the needle will surge upwards before dropping back ? Downwards I could understand as a loss of power / lose connection but upwards ?
Yes, as per the contacts dizzy .I've just swapped back to the points and the surge is gone ?
It sounds like the rev counter is picking up a back feed from the electronic ignition somehow.
I've seen hall effect electronic ignition send odd signals before but not enough to power a rev counter like yours has???
Found it !! It's Bosch unit with 4 downward hanging tangs and when I was checking the bearings noticed that 1 was at a (very) slightly different angle. I adjusted the air gap on the straight ones and confirmed that was the problem. Straightened it up and refitted ..purrfick
Exceeded sell by date
Interesting. During the problems with my ignition my tacho would shoot up Kev.
Finally switched over to MSD yesterday(I know Johnny will not approve!) and all is well with the world.
