Hey Rodders,
The 76 Plymouth 318 in my F100 has all of a sudden started making a tapping sound that gets faster as I rev up. I'm assuming it's a lifter or rod that needs attention, but whilst I try to find time to investigate, will it hurt to drive it about for the time being.
Thanks.
Full Bloody Rebel!
I know some folk run like that for a long time, but I'd rather not risk it! Best be safe and get investigating!
Exhaust manifold bolt/s loose/blown gasket, does it go away when you take your foot off???
Rocker come/ing loose, pull valve covers and check when on tickover (have plenty of rag around) also have a mate to switch engine off...!!!
Coupla things to keep you busy...!!!
Is your oil pressure good?
My old Galaxie started doing that, it was the oil pick up was blocking up with black death and staving engine of oil!
Would damage engine big time if its a case of no oil getting around engine!!!
Cheers Rich
Dragging not Bragging
I had a horrid knocking noise that was driving me made and sounded like metal flexing on the bulkhead/chassis area
Drove me mad every time i went out ................ it transpired to be a metal bracket in the glove box
BUT
After changing my inlet for an after market one i developed a mis-fire which i went through everything dizzy carb timing even down too 3 inlet gaskets due to checking to see if the problem was blocked runners turned out to be 2 broken push rods 1 on each bank and only visable when the rocker covers were pulled it was due to 2 bolts being a tad to long :wanker:
BUT
That was on a small block chevy right?
