Hi
Collected my hotrod today and have noticed that it is dripping transmission fluid after a run out.
Obviously I will have to find the leak, but how do I top it up (you have guessed it, I am no mechanic).
I know autoboxes often have odd procedures to follow to check and top up fluid - can someone tell me.
1. how to check (engine warm cold etc)
2. How to top up
3. What fluid
4. Does it matter if I top up with a different fluid than is already in it
As a reward for reading this thread here a link to me taking aride out through the Hatfield tunnel
1972 Formula 350 owner
That sounded quite sweet until you nailed it through the tunnel! LOL.
Glad you sorted out the top up procedure. I had two leaks on mine, one being the tailshaft seal, although i dont think that would be the case with yours as it leaks after you stop and secondly, i also had oil leaking from the sump pan gasket because some numpty had overtightened the bolts! As i have realised with those pans after seeing that, if its not a stronger alloy type sump pan then they can easily distort and cause major fluid loss the tighter you wind the bolts up!
Marc
