Dragging not Bragging
When i was running the rover engine in the consul i changed the standard thermostat housing for the air conditioning one as it had a threaded hole for the air con sender which just happened to be the same thread and dia as a ford electric fan switch
I ve just been looking on the bay and came across a stat housing for the SBC
Does anyone know if the
1/ The hole would be the same size/thread as the ford switch
2/ Does the later rubber ring stat housings fit the earlier inlets
