1 - 12 of 12 Posts
So having trouble using my welder, it was fine last time it was used 5 years ago!! Keeps burning down the electrode and getting deposits on it, tried more gas/less gas and altering power but still the same. Any ideas?
Welding Guru
Search for gas leaks and make sure all the rubbers around the torch are not split.
Also make sure the collet and collet holder are in good condition , if they are disorted in any way ( including elongated holes) it can cause disruption issues ( it speeds gas flow up into a nozzle jet and this can draw in air due to formation of a low pressure zone near the ceramic nozzle periphery.
I have had all the above conditions over the years and also had the ac/dc switch on older machines break down and track across terminals which lead to interference on the dc side and would burn tungsten points away. ( local specialists replaced the switch and that solved the issue)
Let us know how you get on.
Legs and heels subscriber
What kind of equipment ? Can you reverse the earth and the torch polarity ?
sounds like you were on AC setting but then you mentioned DC welding steel
Discussion Starter · #6 ·
Its a dc only set, cheap snap on 20+ years old but worked okay . Welded my lads drag bikes fine, need to order some new electrodes so what sort . Also will be making up a stainless exhaust.
Welding Guru
I use thoriated (red tip) as they retain the tip the best, you can get ceriated and lanthanated (purple and grey respectively) but they tend to lose the tip after a while and suffer more if contaminated. ( but dont contain the radioactive thorium )
I'm a grown up drunk!
I’ve tried and dont rate the grey ones at all,
Agreed the reds are good but i’ve used the Blue 2%? Lathanated ones for quite a while now that i find work well on both ac and dc and hold their point well.
Welding Guru
Cheers, will give them a go.
Once had some very high quality (almost pure tungsten ) in the late 80s we used on Nuclear work and they where brilliant and would not contaminate and kept sharp points up to 450 amps ( 3.2mm dia) much heavier than standard tungstens.
Tried to find them since but no joy.
Used to use 6mm zironiated on a bakelite water cooled torch when welding big ally castings serving my time in the early 80s, the high frequency would blitz the radio every time. Used a 15 EW lense in my screen which saved my eyes!!!
its a bit late now , but you have your earth lead in the wrong hole !!!
Discussion Starter · #12 ·
Its fixed so yes it is correct, anyway new tungsten's sorted it along with a big gas bottle.
1 - 12 of 12 Posts
