Thought it was about time to rewire the old girl as she is using a tired old capri loom, So I was thinking about purchasing one of the rebel wire looms.
Has anybody used one if so are they easy to fit, also are they compatible with any engine. :)
Care in the Community
Most wiring kits are pretty much the same and universal fit. Even a novice could wire a car using these kits as wires are marked and instructions are simplified.
I'm about to use a Haywire kit from Miles @ Jack Hammer (01252 377403) but have used other kits in the past.
Personally I wouldn't use a rebel kit but it's your choice!
Had good results with premier wiring kits
www.premierwiring.co.uk
If you buy one of the Sierra based ones, the wiring colours should match up with your existing Capri loom. Which will make fitting it easier!
Nick
