Have just bought some RHS heads for my small block ford. They appear to be the beans. Really big, open, free-breathing ports. Brand new valves to match. (Before you ask they are 2.08 and 1.6 inches respectively). I'v also got a twin-carb tunnel ram to go on top.
Upon receiving both the tunnel ram and the heads, the finish provided is basically very rough on both, and has lots of casting marks everywhere. It is very clear that you are supposed to port and polish the heads to the desired finish.
I intend on port matching the heads to the manifold to get optimum gas flow.
I have removed all the casting marks, sanded off all the rough finish with sandpaper, starting on rough grade then moving down to a finer grade.
The job (in my opinion) looks pretty good. There are no irregularities from port to port, I have been very careful to keep all the sanding matching on each port, but the question now, is, how far do I go with this.
Two of my rodding friends say to leave a slightly textured finish is best, to provide turbulence to mix the fuel. They say a mirror finish is bad because fuel condenses on the walls of the head and destroys fuel mixture.
What is best? Mirror finish to achieve best gas flow, or textured finish to achieve best fuel mix?
Any advice gratefully received... Gwil.
