Hi,
I have asked this question in lots of places and had no reply, so thought I'd ask here.
Does anybody know the distance between the Track control arm inner points on a Capri crossmember?..
Cheers
Paul
Hi petespop,
The picture is of an Escort one, I was just showing the distance I was after ;)...
Cheers
Paul
Dragging not Bragging
Well ive just found out that its peeing down .......... after going out in my socks to get this measurement .......... Balancing chassis rails tape measure and camera while getting soaked is NOT as fun as it sounds .....:lol:
Its the hole UNDER the tape :tup:
Discussion Starter · #7 ·
Cheers m8, your a star :D... My crossmember measures 650mm, I was told it was a Capri front end but I'm starting to think its a mixture of Capri & something else... Need to get the rack boots off & measure the rack pivot points :)..
Thanks again m8..
Paul
The Capri crossmember differences are only in the engine mounts, and whether it has PAS. So, you have 4 pot crossmembers, all of which have manual steering. Then there's the mk1 3.0l which has manual steering, and the mk2/3 3.0l which is PAS. And finally, the 2.8i which is PAS, although Americans got Cologne engines with manual racks. You won't have one of those!
They are all directly interchangeable.
