I'm after a set of 4 u-bolts for a 3" axle case but they need to be 9" long, any traders on here got anything in stock?
Or any one able to recommend someone?
Thanks
Gotzy
Dragging not Bragging
9" long ?
Thats quite long mate, Ive just fitted a set round my 9" so 3" tubes but there not 9" long
The ones i got are 6'5" long but they do ones that are 1" longer so around 7.5" but fit 9 leaf Land rover springs
just an example https://www.connectstores.com/lr/sp_2733.html
item C 624028
There are 2 types per axle and the difference is one is squared off on the end but that one is slightly longer
as i say mine are for the 9 leaf springs so the 11 leaf u bolts should be a tad longer and at the price that they are new its not worth messing with :tup:
I hope that i havent confused things too much :tup:
Yeah they are long, 3" spring pack, 3" axle, 1/2" bottom plate, 1" for nuts and washers, 1" for axle mount pads and we're at 8 1/2" so just went for 9" to allow 1/2" flexibilty for the pads to get the wheel where we want in the arch.
Any idea how long the rounded ones for the 11 packs are?
This is the 9 leaf spring so they are only thin
And this is the slightly longer but squared off U bolt for the 9 leaf, the thread was totally past the plate where as the normal ones have the thread still visible on the other side and still have 1/2" of thread out the nut
Discussion Starter · #7 ·
Sorted, JackHammer hotrods stocks 10" ones with 6" of thread, £5 each for future reference.
