New series RAT ROD engine Chevy 383 cid / 470+ BHP the ultimate rat rod engine
Quick spec Chevy 010 block/ high nickle /4 bolt mains, full CNC .030 over , decked & squared , brass frost loaded , CL-77 brg studded main & heads.
Crank RPM USA 3.750 stroke (internal balance) tell'em it's just a 350 :whistle::smoke:
Rods E/W USA 4130 forged 6.00 long / floating pin / cap screw bolts
KB pistons 10.5:1 floating pin 1/16/1/16 3/16 rings
Rings E/W USA 0 gap moly:D
Crank assembly Hines balanced with spec sheet
Cam is custom grind solid , with E/W EDM direct oil feed lifters :smoke:
Heads are new Gen 3 E/W USA ally 210 cc runners , 2.02 & 1.60 SS valves , full CNC , 1.440 dia dual springs , Vition posi seals , 7/16 studs . Warhammer ally full rollers, 7/16 stud mount.
Cam drive is noisey gear drive system by PRW USA :tup:
Oil pump Melling HV 55 with HV pick up / ARP stud mount.
Sump is 7qt SS pan trap door with baffles
Intake is Weiand 1X4bbl tunnel ram / blacked out / epoxy coated black:smoke:
Carb is Holley 750cfm full tricks with dual feed line & black fuel gauge by Marshall USA
Fuel pump E/W USA 110 GHP / COMP CAMS shaft
Covers are custom metal fab'd alum / satin
Breather & PCV custom ally
Altenator 100 amp custom / with billet ally mount kit. Low or high mount kit.
Air scoop SHOT GUN OR BUTTERFLY OR HILBORN your choice8)
Flex plate SFI tag'd , starter is E/W 3.5 HP mini
Torque converter is custom 10" 3000/3200 stall
Flexplate is SFI tag'd 168 tooth , comes with new mount bolts.
Ignition Revolution HEI black cap , Mega-Fire black 8.5 mm wires custom / black Taylor looms
Water pump E/W USA HV alum
Custom cog drive system installed / satin finish
This dyno tested & tuned engine with DVD of test & printout supplied is 100% turn key... load lite & go rat rod'n.. :smoke:
Price 4950 landed UK all fees
Regards Daryl
PS 1 only F/S @ this price / list price landed was 5850... customers gone BBC monster motor.
There is plenty of room in our crates to pack extra goodies with your
engine & all the extra parts ship FREE... save'n you 100's of Queenies on shipping & 100's on the price of those parts.
Here's one of our Chevy 383cid /400+HP engine boxed & ready to sail cross the pond.
