Hi Folks
Just run out of my usual 2K activator and need to paint some parts this afternoon
I do have some old House of Colour Kosmic Kolor Urethane enamel catalist
One tin is KU-100, one Tin his KU-150
Are these OK to use and what's the difference between 100 and 150?
Please let me know ASAP if you can help
Cheers
Al
If this is a show quality job i would recommend leaving it till you have the right stuff, but if its engine bay, door shuts, small part stuff you should be OK Al, HoK is 2;1,1 you might need to adjust depending on the lacquer youre using. As i understand it the difference in KU 100/KU 150 is the later is medium solids, so will have less flow, you can up the thinners a bit to help it along, Bry
