1 - 20 of 20 Posts
in the back of a transit, everything is soaked with it and my tools are going rusty :shock:!!!!!!!
would a roof vent help ?? maybe one of those spinning things you see on some vans or would letting in a vented panel in the sides work ??
anyone know what else i can do to stop or even just reduce it a bit ??
cheers guys :tup:
Chris you have a water leak in there ,you need to find/fix it or your stuck with the problem,A Flitner(spiny thing) will have a very marginal effect on the situation,Get some ouside with a hose and you inside with a torch ! -And remember allways fix a leak from the outside.good luck,Bry
cheers boss
i did wonder about a leak and had a cursory glance at the door seals etc which all seemed ok, its odd as theres no obv water on the floor of the van, just all over the inside of the roof and its dripping off !!!!
i'll recheck with the hose and report back
thanks again :tup:
It can happen, hot air left in the van after you've had the heater on, cold spell on non insulated panels and you have a condensor effectively .It's made worse if you also have a water leak as that will also ride back up in the hot air and recondense.
Mines the same . Deffo no water leak , but there's more condensation on the inside than on the outside in the morning.
Roll on the summer :tup:
Heavy Oiler
If you can park it in your driveway and get an extn lead to it, you can leave one of those 240V tube heaters in there overnight.
You can buy those small non electric dehumidifiers that will suck the moisture in, might help.
Have the same problem with my connect van,try putting a bowl in the back with some salt in it (dishwasher/watersoftner salt) it does help :tup:
Official Drag Addict....
cheap cord carpet and a couple of tins of spray glue......:tup:
richard rawlplug
mines boarded,insulated,underlayed and carpeted,warm and toasty at night....slept in it loads last summer..never had anything rust in it...well only the loadbay floor,wheel arches,rear doors....etc
Discussion Starter · #12 ·
ok guys, gave it a blast with the hose this afternoon and.... nothing !!
undeterred, i broke out the pressure washer - and other than blasting off a bit of wheelarch :D i only had a tiny leak around the bottom of the doors, so unless we've had some 100mph horizontal rain i dont think its got a leak under normal weather conditions,
so it looks like i'll be carpeting the roof at the weekend :lol:
thanks for you input guys :tup:
van condensation
how about a 12 volt 4 inch extractor fan ............never have condensation in my bathroom:D:incheek: I'll lend you the core cutter:pmsl:
mind you it will only come on with the interior light:lol:
0 to 60 in 3 weeks
when i was in the building game i had the same problem .till a old guy at the building yard said buy a bag of kiln dry sand leave it flat and put a few holes in it .cut damp down by half . lasted 2 weeks then got another bag .plus roof vent .worked for me
Defo works well as did in my caravan and that didnt even leak and you will be suprised how much water actually it traps. You can buy little gadgets from Caravan accessorie shops that trap moisture. It sound slike just a build of heat during the day and the normal cooling process on a night. As already said, carpets probably your best bet.
http://cgi.ebay.co.uk/HG-Hagesan-Moisture-Condensation-Absorber-Trap-Blue_W0QQitemZ330390920718QQcmdZViewItemQQptZUK_Home_Garden_Hearing_Cooling_Air?hash=item4cecd55e0e
After a reasonably nice day yesterday my van interior was dry last night when I parked it in the drive.
This morning , quess what ?, yep condensation again. :tdown:
If you have been getting into the van with snow on your boots etc, once the water is in there it just keeps condensing and dripping, unless you dry it out.
Put a fan heater in there, get it nice and warm with all the doors etc shut.
Then open everything up and let the moisture blow away. :D
Repeat until dry, as they say.
You can do it using the van heater, whilst driving along, but it may not get the back warm enough to work fully.
Cheapo cat litter from Tesco Asda etc...use it in my caravan and garage. Just put a few holes in the top. Usually cost's around £1:50/£ 2:00 and last's around a month.
And can be used in the garage to soak up any liquid spills.
what i did with my bedford cf was on a warm day leave all doors open dry the roof then cover the underneath of the roof with spray on carpet glue leave to dry then rub in some chalk dust the condensation will keep returning to the painted surface when the roof cools if it is not coated
1 - 20 of 20 Posts
