Having a clear out so here's some bits for sale - all prices include postage
Ford C4 autobox parts - these all came from a late 70's C4 that was in good working order until I damaged the outer casing lol. Everything you see in the picture, there's also a couple of bags of bolts etc in there that aren't visible and an oil pan that's not in the picture. £40
Ford 9'' axle pinion seal kit (SOLD TO SID) - I believe its all there and brand new pinion seal, crush sleeve, shims and gasket (except the nut which is used - could easily be reused with some appropriate Loctite). Theres also a couple of new O-rings I had spare so I've thrown them in as well £8
Big rolls of quality aluminium oxide paper 120 grit x 1, 180 grit x 1, 240 grit x 1, plus 2 boxes of DA sander discs almost new boxes £20 the lot (SOLD TO BOB)
60mm sheet metal punch brand new in the box used once £15 (SOLD TO BOB)
Brand new air hose and regulator £20 (SOLD TO BOB)
Windscreen tool £6 (SOLD TO ANDY)
