were and who supplies vinyl roof covering and what do you do about the edges ??? same as in the pic but in black
Grahams Powells old Y eh ;) Still debate about whether that was the first or second car from Westbournes moulds , I saw Tony last Sunday and forgot to ask him :( The other one in contention is Steve Goodridges old blue Y , now owned by Steve D on here .
Boyrivens supply most trimmers but you need an account to purchases from them. What you want is everflex hooding material ideally .Won't bag ,stretch ,bleach in the sun or get mildewy when wet.
Best bet is Woolstenholmes , better known as Woolies
http://www.woolies-trim.co.uk/
thanks v much for the link to the suppliers,how do you fix this stuff to the roof and do you have some sort of beading on the edge.?? thanks again
Vinyl Lionel ??
Usual way is hidden mushroom head bolts under the vinyl before wrapping it over the edge, roofing bolts witha square locator are quite good ( zinc plated and cheap ) then silicone seal to the roof. The other way is wrap normally then use Hidem band around the edges , it splits open to put small screws in to hold it down ( using silicine still).
