Hi guys as per title what does a 4 1/2" PCD (4 bolt) wheel fit? bought a set of wheels in stuff for sale, but seller seems unsure as to what the fronts are for; any ideas?
Thanks for that, I was hoping for something more common place, as I need to build up an axle for the front; maybe I can get MGB hubs to fit something!
early falcons, comets and mustangs too. were they the centrelines off v8kitten?
not yet a coffin dodger
if i can remember from my John Brown Wheels days, triumph, datsun, etc . i will try and find my old wolfrace catalogue, we used it as a bible as the end section listed all the cars
if your hubs are 4 stud you could always get the wheels 'double drilled' to your pcd.
Discussion Starter · #10 ·
Unfortunately the hole in the center of the wheel is quite large, i don't think you could use a much smaller PCD (maybe 4 1/4") but as the axle "fitted" is a scaffold pole with rudimentary hubs, it might be easier to use MGB or Scimitar hubs with the advantage of disc brake fitment.
