Discussion Starter #1
After a 3.5(ish):1 english axle or just the diff, or even a 3.09 LSD is you have one (Capri)
4 off 14 or 15" cossie escort style 5 spokes, were fitted to mondeo Si, GTi Escrot, RS Fiasco pref with tyres, nice and clean would be nice.
Can meet at HRD if you're going
0778 3000 949
Jeff
You won't fit a 3.09 Capri diff into an English axle! They're rarely LSDs, and if you find one it's normally knackered.
Nick
got a set of 16" mondeo 5 spokes (look the same) with tyres, all good, some scuffs but not bad £80. can take to hotrod drags. neil, 07718 339011
Discussion Starter #4
A provisional yes, let me see if I can get 16's on first. I'll borrow a pair of a mate and see if they'll go under the arches
Jeff
Banjo snapper.
The longest ratio available as standard for the English axle is a 3.54:1 found in RS2000, 1600 Sport/Ghia Escort ect. The only LSD offered as standard was in the 2.8i Special & the 280 Capri, both in a Salisbury type axle. Some small engined hatchback Capris had an English often fitted with 3.77:1, maybe you're getting a bit confused?
