I'm building a Low Cost Hot Rod.
The chassis is my own version of a Haynes Roadster or Locost.
It's got a megasquirt'd 4.6 Rover V8 and 4x4 running gear.
I made a crude wireframe from the wooden buck (I'm making a new open style buck)
The body is going to be made from 18awg steel. I've never done anything like this before. This is my first car project and I don't work in the industry so I'm learning everything as I go. I've only just learnt to gas weld, so welding a car together is a little challenging.
I'm starting the body by using the hinge pins as a reference. If I can get the hinge pins identical on both sides there be my datums.
I'm going for modern style hinge pins
Everything is being done on the cheap. I'm making an English wheel and I've made my own bead roller, sheet metal roller and folder.
I'm a newbie at all this, so any help and comments very welcome.
You can read more here: Home - Super 7th Heaven
