hi guys im thinking of putting a wood floor in the morris only the two main runs from under the seats to the bulk head as im going to have servo, fuel pump and other bits under there so will need access. trans tunnel, rear floor and boot will be steel.
my question is am i best using marine ply and would 1/2" thick be enough or am i better using 3/4"?
personally id use steel, you could maintain servo etc from underneath, if you wanted to you could make removable with nutserts
