I am using Millers Classic mineral which has a reasonable level in it (700 or 900 ppm - not sure) - one of the US oils (can't remember which one but will find out) has the highest level 1200 0r 1400 ppm - there is a point where a higher concentration actually has a negative effect - there was quite a lot of info on some of the US forums a couple of years ago - I may have downloaded some - will have a look when I have a minute.Additive with ZDDP, the oil I have is API SE CC spec ( cars up to '79 ) so is meant to be up to spec but I'm cynical![]()
Valvoline VR1 - link gives its make-up http://www.valvoline.com/pdf/VR-1_Racing_Motor_Oil.pdfI am using Millers Classic mineral which has a reasonable level in it (700 or 900 ppm - not sure) - one of the US oils (can't remember which one but will find out) has the highest level 1200 0r 1400 ppm - there is a point where a higher concentration actually has a negative effect - there was quite a lot of info on some of the US forums a couple of years ago - I may have downloaded some - will have a look when I have a minute.
